Need advice on system's psu!
andreas_vak
236
so i have this question:if i have a 3570k and OC it plus 2 evga 670 ftw in sli 1 hdd 1 ssd whats my safest power supply??i know about brands...without the OC of the cpu whole system is 516 watt...if i OC both gpu,cpu what should i get??600,650 or something else plus i dont know what 80 plus bronze,silver;gold means...
andreas_vak
236
no i'm buying so i'm looking from every angle....if dont OC then my system will be 516....so how much is the safe??600..remember no OC nothing
750W is what you should get for a dual card rig.
80+ Certified, 80+ Bronze, Silver, Gold, Platinum and Titanium all refer to the efficiency the PSU has when it converts AC Current (wall power) to DC Current (power the computer can use). An 80+ Certified PSU is guaranteed to be at least 80% efficient under loads between 20% and 100%. The better ratings (Bronze, Silver, etc...) refer to higher levels of efficiency.
80+ certification also specifies other things as well, such as having the rail voltages not deviating more than 5% than their rated value.
