could i get some Advice on pairing usb c docking gear & my Lenovo Flex 5 Laptop
will this Kensington Triple Display USB-C Docking Station with 100W PD
work with my Lenovo Flex 5 Laptop, 14.0" FHD Touch Display, AMD Ryzen 5 5500U
an is this a reputable an trustworthy brand an correctly spec'ed Right Angle USB
the LEIRUI 100W USB4 Cable 2.62 FT Thunderbolt 3&4 Cable Right Angle USB
to pair with the dock am my laptop , if not can you point me to one
also which is better the Kensington dock or this targus USB-C Multi-Function DisplayPort Alt. Mode Triple Video Docking Station with 85W Power
an instead of them stated right angle cable do you think these are reliable an legit
usbfever USB4-usb-cables/right-angle-usb-4-usb-c & 90-degree-right-angle-usb4-usb-c-female-to-male-adapter
as my plan is to mount dock to back of screen an use the
usb c port that free for power an dock hub so as to get
power an still have access to extra usb ports
right now im using a its regular power plug to power an keep
the c free but im not crazy about have plugs stick off straight off the side.
id much rather have that bulk of gear at the back vi hub an
a low profile right angle plug on the side , is all the listed gear a viable combo
_
one finale question if all this is doable can the AMD Ryzen 5 5500U adequately drive three 60hz screens
_
