Need advice on which custom cables to get (cablemod)
hijackxd21
Proper
May 4, 2018
62
Hello,
It's my first time building a gaming pc and I want it to look sweet, so I want to get some cablemod cables, but I saw that there were a bunch of options, like basic cable kits, and essentials cable kits. I just want the cables that can be seen to look good, but I have no idea which ones those are. Any help would be appreciated :)
Also, what are those cable comb things? I have no idea what they do.
Basically, you would want any cables that will be visible or partially visible but that depends on your system. Normally would be 20/24 pin main, 4/8pin aux for MB and GPU/PCIe cable(s), eventually HDD power too. Most of good fans have also braided cables. Comb is a piece of plastic with notches in them to keep various cables apart and tidy looking.
