Need advice pls on cards for video/graphics processing and editing. Should i upgrade what i have now?
SZNJ732
Commendable
May 6, 2016
Dear friends!
I desperately need some advice, so far i have not been able to find a good, clear answer.
I will try to keep it short and to the point. Here is what’s going on:
I recently got involved in video and photo editing. Mostly video.
I'm looking to optimize/speed up/improve my system processing capabilities.
1) - How important is it to have a good graphic card vs. good PC specs when it comes to video processing? I’m not really interested in games/gaming.
Right now I’m working with: Adobe Premier Pro 2015, PhotoshopCS6, CyberLink PowerDirector 14 (64-bit), Pinnacle Studio 18.
2) - My main questions is: should I invest in a decent graphic card, and what kind of improvement can I expect with a better card?
Or is more important to have better system specs such as CPU, Ram, etc., and just get an OK graphics card. Or should I just keep the card I have now?
Looking on Amazon, thinking about these:
EVGA GeForce GTX 750Ti SC 2GB GDDR5 Graphics Card -- $110
EVGA GeForce GTX 960 4GB SSC GAMING ACX 2.0+, -- $200
EVGA GeForce GTX 970 4GB SSC Gaming ACX 2.0+, -- $330
My current card I bought like 7 years ago for around $400.00. Still using it today. I build my own PC in Jan of 2015.
Any help would be greatly appreciated. Thank you!!!
Here is what I’m working with now.
APPROXIMATE PURCHASE DATE: next 1-2 weeks. BUDGET RANGE: ~$200-$350
SYSTEM SPECS:
Operating System
Windows 7 Professional 64-bit SP1
CPU
Intel Core i7 4770K @ 3.50GHz
Haswell 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 799MHz (10-10-10-27)
Motherboard
ASUSTeK COMPUTER INC. Z87-A (SOCKET 1150)
Graphics
1024MB ATI Radeon HD 4800 Series (ATI AIB)
Monitor1: ASUS VS247 (1920x1080@60Hz)
Monitor2: ASUS VS247 (1920x1080@60Hz)
Storage
232GB Samsung SSD 840 EVO 250GB ATA Device (SSD) 34 °C
298GB Seagate ST3320620AS ATA Device (SATA) 45 °C
279GB Seagate ST3300831AS ATA Device (SATA) 38 °C
3725GB Western Digital WD My Book 1230 USB Device (USB)
1862GB Western Digital WD My Passport 0820 USB Device (USB)
59GB TS-RDF5 SD Transcend USB Device (USB)
Power Supply: 750 Watt.
More specs on the card:
Manufacturer ATI
Model Radeon HD 4800 Series
GPU RV770
Device ID 1002-9440
Subvendor ATI AIB (1787)
Current Performance Level Level 0
Voltage 1.263 V
Technology 55 nm
Die Size 256 mm²
Transistors 956 M
Release Date Jun 25, 2008
DirectX Support 10.1
DirectX Shader Model 4.1
OpenGL Support 3.0
GPU Clock 770.0 MHz
Temperature 72 °C
Core Voltage 1.263 V
Driver version 8.970.100.1100
BIOS Version 113-BA0702-X02
ROPs 16
Shaders 800 unified
Memory Type GDDR5
Memory 1024 MB
Bus Width 32x8 (256 bit)
Pixel Fillrate 12.3 GPixels/s
Texture Fillrate 30.8 GTexels/s
Bandwidth 115.2 GB/s
Noise Level Moderate
Max Power Draw 150 Watts
right now nvidia just drop there 1070 card. there launch video gave the 1070 for 329.00 price point speds faster then the older titan x gpu. also amd pascal 10 gpu when they drop there going to be about the same speed as nvidia 980 per leaks at a lower price point. also going to have a 170w max. if your pinching pennies i would wait for the newer amd gpu. it give you a lot more bang for the dollars. unless your video editing hardware would work better with a nvidia gpu.
Great, thanks for the suggestions.. i just looked this up:
"The GTX 1080 will retail for $599, $50 more than the GTX 980 cost at launch, while the GTX 1070 will retail for $379 , again $50 more than the previous generation card. The 1080 launches on May 27, with the 1070 following on June 10."
I think i'll just wait a month and get the 1070
