Thread closed.
[strike]Dear Tom’s Hardware users
I need some advice to fix my build. In the past ½ year, it feel more or less like I keep throwing money on something that is just not performing as it should. Even if I’ve done everything to insure maximum performance
Now to the build and the issues.
Build
CPU: I7 3770 3,4GHz “not overclocked”
GPU: Radeon HD 7970 ”Not overclocked”
MOBO: EVGA Z77 Stinger
RAM: Cosair Vengeance 8GB ”not overclocked”
HDD: 2x Kingston HyperX 3K 240GB
PSU: Be Quiet Dark Power Pro 10 650W
Fans: 4x Noctua NF-F12 PWM and 1x Noctua NF-P14 FLX
Case: Cooler Master Cosmos II
Water Cooling: Complete EKWB set with Laing 1plus (18W) Pump.
GPU: Full cover block.
CPU: Supremacy Nickel.
RADS: 1 x dual 120 65mm. 1x single 120 65mm. 1x single 140 65mm
Now to the issues
CPU: When I made my build, I ask around what the best and most efficient CPU were. The answer quick. Intel Ivy Bridge. It is expensive, and consume almost no power. However, have I never had a CPU that have been such a corner- cutter and downright dreadful when it comes to cooling it. It’s like fighting a nuclear reactor on its way to meltdown. It stays at 31.C at idle and 65.C under load.
Just to kill the fact. Yes, the thermal past is placed and applied correctly and the thermal past is Arctic Silver 5
GPU: I see my Radeon HD 7970 as an anti-material rifle. Powerful is all its specs. Nevertheless, the issue is that its scope is a toilet paper roll (Its driver). Bugs, bugs, bugs and performance issues. Yes I could downgrade the driver, but that will only leave me with another very annoying fog/smoke rendering issue.
Therefore, my question is. Is the green grass on the other side better or do I have to stay with my red grass.
Cooling system: Lately I found out that my pump is u unstable and sometimes do not run (have nothing to do with my CPU heat issues). The easy solution would be to just buy a new pump. But by time I’ve both grown paranoid and annoyed by the many issues and the maintain requirements just to keep it cool’n’quiet
So what do I do here? If my desire is to have a PC that does not make more noise than a whisper and Is still able to keep the system cool. [/strike]
Build
Now to the issues
