Need advice with gaming build
skitor
17
CPU: Intel® Core™i5 Quad Core Processor i5-4670K (3.4GHz) 6MB Cache
Motherboard: ASUS® Z87-A: ATX, USB2.0, USB3.0, SATA6GB/S, SLi, XFIRE (not to sure about motherboards)
RAM: 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT)
GPU: 4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk: 120GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
2nd Hard Disk: 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply: CORSAIR 650W ENTHUSIAST SERIES™ MODULAR TXM-650 V2-80 PLUS®
Sound Card: Creative Sound Blaster® Audigy Rx(£52)
Genuine Windows 7 Ultimate 64 Bit w/SP1 - inc DVD & Licence
Build: £1334 Willing to go to £1500
I'm just saying it's not necessary for a gaming rig.
Reasons to keep SSD 1. It will make you look rich 2 faster boot up time 3 game launches faster 4 if hard drive fails, you have your windows files on a SSD so you dont need to redownload windows, also i like to keep backups of everything i have so i have a second hardrive for that.
DEF keep the ssd. 100%
Hell, it will play most games on ultra for the next couple years. And keep the ssd just for bootup times, it is nice to have.
Dude, I love my 180 gb Intel SSD. Enough room to hold my primary games and about +$50 more than a 120 gb SSD.
An SSD is not required - unless you want to smile every time you turn on / wake up your computer :)
I will never build another computer (for me) without and SSD. PERIOD.
I would suggest getting a 780 if you want to play on ultra and very high for the next couple years
Thanks alot. Is there a way i can buy the cm stormtrooper case with green fan leds in it ? Tryed looking cant see it. If not what tower whould be good for air flow and looks good with leds ect..
that is the case i have, i actually have two, the stryker and trooper... same case just one's black one is white. really awesome case.
You little buttcheek. AMD R9 290x comes with an overclocking system and a free copy of BF4. It also does a little bit better than the 780. ANd it comes with 4GB ram whilst the 780 comes with 3.
