Need advise for a case!
The all black case would look fine if you want black and red made one of these cases
https://pcpartpicker.com/product/tD38TW/nzxt-case-cas340wbr1
https://pcpartpicker.com/product/m78H99/rosewill-case-gungnir
I use the H440 its a bit over 85 like 110
[/URL][/img]
For cable management, just take your time and plan out the best way to run the cables ....... you might need to add ext to them whare you want them.
this is a older i5 3570k build I did....... I even drilled holes around the mobo in the case and but the cable right where I wanted them and used rubber around the holes...
[/URL][/img]
[/URL][/img]
Nice build man, looks good and clean cable management, i really like that NZXT s340 but looks like there's some incompatibility with the optical drive...but anyway i'll be getting either a rosewill or NZXT. Thanks!
Yeah a lot of builds don't even have a CD most just use a external cd for the few times its needed
gl on the build
