Question need aio cooler help
Nov 1, 2020
6
ok so. i buyed my brother a aio cooler(Corsair iCUE H150i ELITE CAPELLIX Liquid).link 2 the cooler on amazon
but after a day of he using it it now flashing red and the fans r at full speed but the temps look fine
it said in icue software app that it has a pump failure so
what do i do
and the pump pipes r facing upwards if that matters the rad is on the top an after we unplug a cable then pug it back in with the pc on it does back to normal
any help with be appreciated.
punkncat
Dignified
Ambassador
First, would probably just go through and verify all the connections are in the proper placement and secure. Follow up with a look in BIOS. If the pump is spinning it should show RPM in the BIOS. It might be indicated as a fan. The I cue software may also have that feature.
In a case like this, if there is any question I would likely return it for an exchange. These units are well reviewed, so it's certainly not junk.
