Need any advice on my build.
FelixMcFly
Commendable
Apr 29, 2016
174
Soon I'm going to order all the parts for my rig. Need to quickly make sure if everything will be fine with my gaming rig. This will be my first ever build.
Im trying to play games like days, arma3, subnautica, h1z1, rust, arc, and more things like that.
Need to know if my pc is good enough and any modifications that can improve my pc. Im on a budget of $650.
http://pcpartpicker.com/p/R6fwwP
Skip the cooler and upgrade the CPU to i5-4590. It turbos to 3.7Ghz. compared to the i5-4460 3.4Ghz. You don't really need the cooler. The stock Intel is fine.
really? i thought u needed the cooler
especially if u wanna turbo boost. Well whatever, the i5-4590 does seem better. Thanks
not a bad thought but couldn't he just OC the 4460? then he could get good cool performance without a struggle
no wait bro I'm new to this website and i didn't know what the arrow meant. I was trying to reply to you.
