Need approval for first build. 1300$-1500$
Paul456
4
Approximate Purchase Date: May 3rd 2012
Budget Range: 1300$ to 1500$ with taxes (15% in Quebec)
System Usage: Gaming
Parts Not Required: OS (windows 7)
Preferred Website(s) for Parts: http://www.microbytes.com (local dealer)
Country: Montreal, Quebec, Canada
Parts Preferences: N/A except Intel processor
Overclocking: Yes
SLI or Crossfire: Maybe in the future (1 year +)
Monitor Resolution: 1920x1080
CASE ATX COOLER MASTER HAF 922 BLACK NOPS
http://www.microbytes.com/product_info.php?cPath=1_33_34&products_id=20750&osCsid=d2408ade48c20757c7cc46a3ae856173
INTEL CORE I5 2500K 3.30G/6M/S1155 (planning to wait for i5 3570K unless u guys say not to)
http://www.microbytes.com/product_info.php?cPath=1_66_67_133&products_id=36691&osCsid=d2408ade48c20757c7cc46a3ae856173
2.5 SATA3 128.0 CRUCIAL SSD M4
http://www.microbytes.com/product_info.php?cPath=1_19_164&products_id=38090&osCsid=d2408ade48c20757c7cc46a3ae856173
S1155 ASROCK Z68 EXTREME3 GEN3 Z68
http://www.microbytes.com/product_info.php?cPath=1_7_134&products_id=38907&osCsid=d2408ade48c20757c7cc46a3ae856173
DVD+/-RW ASUS DRW-24B1ST SATA DL 24X OEM BLACK
http://www.microbytes.com/product_info.php?cPath=1_51_62&products_id=33838&osCsid=d2408ade48c20757c7cc46a3ae856173
750W ATX SEASONIC 750HT80-A2 OEM
http://www.microbytes.com/product_info.php?cPath=1_2&products_id=33204&osCsid=d2408ade48c20757c7cc46a3ae856173
CORSAIR VENGEANCE 1866MHZ DDR3 8GB KIT CL9 RED
http://www.microbytes.com/product_info.php?cPath=1_16_38&products_id=39896&osCsid=76dae36fa9b1d49afc638b1c1d27cc62
EVGA PCIE GF GTX570 1280M BOX (i can afford the 60$ extra for the 7870 but i would prefer Nvidia)
http://www.microbytes.com/product_info.php?cPath=1_24_25&products_id=36471&osCsid=d2408ade48c20757c7cc46a3ae856173
That's it :D
I won't suggest IB as IDK when it will release in Canada. 1866 MHz nets you no improvements and is just a waste of $. Either get 1333 MHz or 1600 MHz because 1866 sees no real-world advantage. You forgot the cooler. I have the Hyper 212 EVO and it keeps my temps down; however, it is kind of a pain to install.
serialkiller
915
Excilent choice but needs improvent.
If ib releases then get it or be happy with sb.
Asrock z77 extreme4
newer better and cheaper motherboard.
Corsair vengence low profile 2 x 4 gb 1600mhz ddr3
1866 is overkill and your pc will default your ram frequency to 1600 or 1333 or 1066.
Pc power and cooling silencer 750w 80+ silver.
Cheap better psu for a deal.
Sapphire hd 7870 ghz edition
it is the best bang for buck gpu for now. and beats gtx 580 in each and every way.
Also checkout the corsair carbide 500r white and cm storm sniper.
Also dont forget to add cpu cooler.
Cm hyper 212 evo can oc i5 2500k upto 4.5ghz is all you needed and give best bang for buck performance cpu cooler.
