Need assistance in attaching a wireless headset
Shakespirit
I recently purchased a Samsung Smart TV, and I would love to attach my wireless headset that I had previously used on an old set. How do I go about getting it to work on my new bells and whistles, luxury set?
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=167827&modelname=LN46C750R2F
If you are using a pair of self amplified headphones you can connect to the "Audio Out" on the rear of the TV. Most wireless headphone sets will come with an adapter to use to connect to the audio out..
If your wireless headphones are not self amplified they can be connected to the TV but you cannot control the volume level of the headphones. If it is too loud or too soft you cannot adjust it because the audio outputs are fixed audio out.
