(Not sure if this is the right place to post but oh well)
Hey all.
I decided to build my first PC after all of my friends were bragging with their superior PC's. My brother and I have connected everything up but when we plugged it up to the mains, it started booting up and turned itself off. Then, a few seconds later, it started to boot up again. It then turned off again. We've taken it all apart and put it back together again as well as made sure all of the cables are in properly. The CPU is in properly, and the CPU fan is working.
All we could think of which would cause this is either the power supply isn't good enough for the system or it's overheating. I didn't get any external fans because the case has a couple of fans built in. My components will follow.
If you could try and help, I'd be real grateful. Also, try and leave it in simpleton terms. Thanks!
(I didn't want to spend crazy money on my first build so thats why the parts may seem rubbish)
Component list:
- Gigabyte GTX 970 Graphics Card
- Intel Core Skylake Processor i5-6500/3.2 GHz
- Crucial BX100 120GB SATA 2.5inch Internal SSD
- Seagate ST4000DM000 4TB 5900rpm 64MB Cache SATA III HDD
- Gigabyte Z170XP-SLI Intel Skylake ATX Motherboard
- Corsair CC-9011013-WW Carbide Series 500R Case
- EVGA 100-B1-0500-KR 500W 80 Plus Bronze Power Supply
- HyperX FURY Black Series 8GB 2133 MHz DDR4 CL14 DIMM Memory Module (skylake compatible)
Parts on order:
-Corsair Air Series AF120-LED 120mm Quiet Edition High Airflow LED Fan
Pictures of inside case available on request
Thanks again!
Mr Shotz
Hey all.
Component list:
Parts on order:
Thanks again!
Mr Shotz
