Need Asus SK8N help
jeff
1,172
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I'm seting up a AMD 64 FX-53 system. I have to keep this short. I
installed every thing power it on and got 1 long peep and 2 short beeps. So
far I've done:
Installed new flashed bios chip.
Tryed 3 video cards. APG and one PCI
Tryed 2 kinds of memorey ECC.
I don't know what the peeps mean. Dose any one have any ideas.
Jeff
In article <10ak41jh9uh8t12@corp.supernews.com>, "Jeff"
> far I've done:
> Jeff
Section 7.2, last page.
ftp://ftp.asuscom.de/pub/ASUSCOM/BIOS/POSTCODE_BEEPCODE/ami_code.zip
What is the part number and brand of the memory you are using ?
For a single module, are you trying it in A1 or A2, as
mentioned in the manual ?
Paul
Are you using ECC registered RAM?
Dom
"Paul" <nospam@needed.com> wrote in message
news:nospam-1805041419200001@192.168.1.177...
So
> > far I've done:
> > Jeff
> Paul
Someone else had this problem with the POST beeps, said they reseated
their CPU and the problem disappeared.
"Jeff" <jwright1@nospam.coserv.net> wrote in message news:<10ak41jh9uh8t12@corp.supernews.com>...
> far I've done:
> Jeff
> "Jeff" jwright1@nospam.coserv.net wrote in message
> news:10ak41jh9uh8t12@corp.supernews.com...-
> beeps. So
> far I've done:
> Jeff-
I had similar problem after I swaped my two KVR333X72RC25/256 to
KVR333X72RC25/1G (frmo 512MB to 2GB). The old memories used to work
fine on dual-channel mode (A1 and A2 slots). The new ones don't work at
all in dual mode.
I managed to use the new ones on A1 and B1 slots in single-channel
mode (but without using the old memory cards at the sametime).
If I revert to the two 256MB cards, they work in dual-channel mode
again.
Does someone know how to fix that? I use a Opteron 140 with 1007 BIOS
(tried 1008 Beta 3 as well, same results).
rodmont74
Latest posts
