Question Need best case for water cooling
Sep 24, 2019
my PC spects
intel i9-9980XE 18 cores
Mother board Asus rampage vi extreme x299
I need a best case with water cooling supportD
Eximo
Herald
Best, going to be massive, and custom. Not sure who makes the most ridiculous cases now that Caselabs is gone. Try Lian Li.
If you want something more basic like a full tower, there are plenty out there that support 480mm radiators and the like. Cooler Master, be quiet!, Phanteks, all come to mind for full towers.
You've only listed two components, and to be honest, the chassis necessary to cool only that can even be a just a largish mid-tower. Basically just needs to support a wide motherboard.
Your selection is going to be driven by radiator sizes and component selection. Are you mounting any 2.5" or 3.5" drives? Adding GPUs to the cooling loop? Going with a large reservoir and pump?
Reactions: Rakeh2010
Phaaze88
Admirable
Herald
I've got my hands on one... NO REGRETS.
Can fit 420 and 480mm rads in here! I was debating between this and the Lian Li O11-Dynamic XL, and the Luxe 2 just offers more options.
You're stuck with 120mm type fans and rads in the Dynamic - that may not bother you, OP, but I wanted FLEXIBILITY for the case that'll hold by future LC setup.
Reactions: Crosslhs82x2
