I built my watercooling probably about a year ago. Has been running fine. QX6700 3.20 temps at idle around 51-53C. In the summer idle temps can be about 7 degrees higher. Anyway, at the recommendation of someone here in the forums, I went with this fan:
http://www.sidewindercomputers.com/de12trblhisp.html
I had already bought Yate Loons but this guy was totally sold on these so I bought them. I have 3 mounted on a 120.2 outside of my rig. They are mounted to pull air through the radiator. They are each separately controlled and I'm using a separate power supply.
So the problem? Frickin noise. When I first built the system, I thought to myself, "Hey, noise is just the price you pay for good cooling", but I can't deal with it any longer. I'm enjoying Bioshock, Warhammer, etc and the noise is no longer acceptable. So what would you do? I think my current temps are about par for this CPU. It runs rather hot anyway but I also have two GTX 260's not on the loop and I wouldn't want to see temps in the box rise much more. Although with this Thermaltake Armor case, there are fans galore. So would you try replacing the fans or a larger radiator or..?
