[SOLVED] need buying guide
Oct 8, 2019
12
hey fellas a few days ago i kinda lost my old pc and with lost i mean a bottle of water standing on my desk... ye you get the point after some testing i found out the cpu and gpu are still working fine lucky me i guess anyways i need to build a new system around those 2 components and could really need some help on what to buy
the parts i have are the msi gtx 1050 ti and a ryzen 5 3600 my current case is pretty small and i already ran into some problems on my last build so acase recomendation is also very welcome my budget is 400-500 euro german market here the build should be focused around gaming thats pretty much all the pc is going to be used for still got my laptop for other things at least
thanks in advance and may the water bottle be closed the next time
Sorry about your bad luck. I've put together a modest build around your two surviving parts. Take a look and see what you think:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (Purchased For €0.00)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard (€92.89 @ Mindfactory)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory (€99.08 @ Amazon Deutschland)
Storage: Crucial MX500 500 GB M.2-2280 Solid State Drive (€69.65 @ Amazon Deutschland)
Video Card: MSI GeForce GTX 1050 Ti 4 GB Video Card (Purchased For €0.00)
Case: Corsair 200R ATX Mid Tower Case (€59.90 @ Amazon Deutschland)
Power...
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply (€91.63 @ Amazon Deutschland)
Total: €413.15
Generated by PCPartPicker 2020-02-06 13:18 CET+0100
The new motherboard supports your processor out of the box. No need for BIOS update worries.
16GB of DDR4-3200 RAM is pretty standard these days.
Modest, but decent sized case on the less expensive side.
Modest power supply. If I were to spend more money, it would be here. (look for a newer Seasonic Focus Gold unit).
-Wolf sends
Total: €413.15
-Wolf sends
thanks alot for the advise just ordered the motherboard and psu found a older corsair 100r case and will see if i can fit everything in there if so i would probably spend a the rest for a new cooler do you have any in mind? should get something decent for around 60 bucks right?
It will fit in the 100R. HDD cage may have to come out if you eventually get a longer gpu.
All in a 100R case;
No. I generally stick with the stock coolers, but the Noctua's seem to be favorable.
-Wolf sends
