need case for big motherboard and gtx 1070.
specz3
Commendable
May 16, 2016
28
case with big size ? around £30-£40?
I'm installing gigabyte motherboard and gtx 1070.
I need a big case for them.
Most midtower(ATX) cases will take what you have.
What board are you getting since mATX cases would work if you are getting an mATX board.
As for price that is not allot for a case, do they still sell the Antec One Hundred in your area, those are fairly cheap with decent space(this does depend on the length of your video card).
The Corsair Carbide SPEC-01(or the 100r) may be in the right range with plenty of room.
What stores do you shop at?
thanks so much man you saved my life :pt1cable:
I usually order pc stuff from amazon :) .
