i have a few question regarding moving to a new case (from carbide 400c to obsidian 500d rgb)
My old cooler (though its still 4 month old) is H80iv2, fitted into carbide 400c (front, upper side)
My gpu is zotac 1080ti amp ext, spec length is 325mm. as it is, its very tight fit between gpu and the cooler
and im about to move to obsidian 500d.
1. would i be able to use H150i PRO RGB with my new case? would it fit with the gpu? is it more wider/narrower than h80i?
2. if im not upgrading my cooler (and stay with the h80i), can i still use the obsidian's included LL fan for push and the h80i's SP fan for the pull, or did they need to be the same type of fan?
cheers
cheers
