I've finally picked out the majority of parts and am almost ready to order everything but I just need some confirmation/reassurance that I can order every thing, wait for however many weeks it will take to get the parts, and then build my pc with no problem with any compatibility or other issue. I will link my build: http://pcpartpicker.com/p/6ZsQvK. I still need to find a good CPU cooler if anyone can recommend one. I also want to make sure that the EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply is right for me or if I should go with 750w or some other amount. The last thing I need help finding out is how I should set up my Fans. The Case is 900d and I was thinking (I'm going to use Corsair AF120/140 quite editions) 3 in the front bring in cool air, X amount on the top bring cool air, 1 140mm in the rear expelling hot air, and then X amount on the side expelling hot air. I don't know about setting up fans so any help would be appreciated. Thanks
