Need cooling fan
millardjacobs
I need an acer inspire AX3400G-U4802 Cooling fan.... can anyone tell me where I can find one or one that will work in it's place?
Cheaper and better just to replace the whole cooler. Anything that fits AM3/AM2+ mobo's and is short enough will work.
CPU Cooler: ARCTIC - Alpine 64 PLUS Fluid Dynamic Bearing CPU Cooler ($11.88 @ OutletPC)
Amd stock coolers were miserable, not doing a very good job at all unless running at full speeds (with its associated noise), so generally a 1/2way decent aftermarket cooler is usually recommended.
Hi I found it but no wires? dumb question maybe but does it come with wires? thats whats wrong with mine, mines wires are torn and the fan constantly runs and shuts down the computer from time to time.... thanks so much for helping out
