Question Need EATX case suggestion for top mounting Arctic Liquid Freezer II 360
Feb 18, 2024
Hello guys,
I am doing a 14900k build with Arctic Liquid Freezer II 360mm as my AIO, MSI MEG z790 Ace Max as my motherboard and ASUS TUF RTX 4080 as my GPU.
I'm looking for a case where I can mount the AIO on top without any issues and also have enough airflow since the pc will generate a lot of heat inside the case.
I've been looking all over but can't find a the right case (the only thing in my build that I'm still not sure about).
I just bumped into this forum and thought you guys could help me out here, I would really appreciate your recommendations.
Some important note:
Be Quiet, Fractal, Phanteks, Inwin cases are not available where I live.
I can just get a "Lian Li O11 Evo XL" and forget all my worries but I don't want to spend that much on a case.
I liked the "Montech King 95 Pro" case but that doesn't support EATX and another case I looked at which I liked was the "Gamdias Neso P1" but I'm not sure about the top radiator clearance for the Arctic AIO.
Where do you live? How much have you allocated towards your case purchase and what sort of sites do you have access to? Region will impede product and brand availability so the more information we have. the better it is for you.
Sometimes when all options are stifled, the most likely answer has been staring you at the face from under your nose all along. Just saying.
