I have a custom built pc with a Asus Tuf X299 Mark 2 that had two 8gb G-skill 3200mhz sticks of ram that is set to xmp in my bios with a xmp profile with timings set for the two 8gb sticks i belive. I tried adding two 16 gb of Corsair Vengeance 3200mhz. Its not running at proper speed and the only slot its worked in arent the recommended ones. below are some pictures of my bios and Cpu-z and HWinfo64 to show you how the memory is running. I would really appreciate some step by step instructions to get this ram running correctly at the correct speed. Thank you
Bios
https://1drv.ms/u/s!As-F1kUKcKx2lAG5uNw6m4oFE9Jw
Hwinfo64
https://1drv.ms/u/s!As-F1kUKcKx2lATvED5TzEMpk06L
https://1drv.ms/u/s!As-F1kUKcKx2lAVw-YEFMnOe4cR5
Bios
Microsoft OneDrive
1drv.ms
Hwinfo64
Microsoft OneDrive
1drv.ms
