need expert opinion on my first gaming build
Cristiano_4
Commendable
Sep 3, 2016
28
hi,
i wanted to read someone else opinion before starting to buy anything.
http://pcpartpicker.com/list/Ns3Y9W
just a couple things to note:
i will use another HDD (not in list) and i already have a 250 Gb SSD.
i will use a 750W power supply (not in list).
all opinions and suggestions are welcome.good or bad
Don't see any reason for Windows 10 Pro, so I would recommend Windows 10 Home. I'd also look at a different power supply.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($324.99 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler ($59.50 @ OutletPC)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard ($142.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($79.88 @ OutletPC)
Storage: Seagate 2TB 3.5" 7200RPM Internal Hard Drive ($130.48 @ Amazon)
Video Card: MSI GeForce GTX 1080 8GB GAMING X 8G Video Card ($719.88 @ OutletPC)...
There is zero reason to use a 750W power supply with a system that should be about 225-250W when gaming. It is counterproductive because it'll be less efficient, so higher electricity bill, and it'll produce more waste heat. On the other hand, you can get a 550W unit or 450W unit for a cheaper price which is just as good and will be more efficient.
in that case i think i will go with the 650 W. i will be using some lights and other stuff that will also need some power :) 20$ saved
Your list looks nice, only thing I can suggest is maybe down grading to a I5 6600k cpu. I'm upgrading from an AMD cpu soon so I been watching vids and 1 my fav LinusTechTips had a great video last week comparing ALL Intel cpu's, and he explains why a i5 is more then enough for most gaming rigs, and he gives u a few reasons why it might be worth it for the i7. Not saying ur pick is wrong, just a video that offers food for thought, good luck! https://youtu.be/toZ_t88bPBU
Case: Cooler Master HAF X ATX Full Tower Case ($179.65 @ B&H)
Power Supply: FSP Group Hydro X 650W 80+ Gold Certified ATX Power Supply ($81.30 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($88.88 @ OutletPC)
Monitor: AOC G2460PG 24.0" 144Hz Monitor ($379.99 @ B&H)
Total: $2187.53
Generated by PCPartPicker 2016-09-03 13:45 EDT-0400
That's $100 in savings over your current build.
-Wolf sends
i went for the pro instead of home because it was a small difference.
as for the power supply i changed for a corsair RM550.
