I have approx 500 DVDs (with thousands more to come) that I am about to sell and I need to scan the front and back of the cover so they can be displayed on our website.
I am currently using a USB2 Lexmark flatbed scanner but it takes about 30 seconds to scan each side.
When you consider scanning both sides, and the time to flip, crop and save the image, the fastest I can do it in is 2 mins and 20 seconds per DVD (saving 2 images) - and believe me I am using keyboard shortcuts and everything to try minimise time.
To do this 500 times will take me days to finish so I am looking for another solution that will help speed this up.
I am thinking there must be some sort of document scanner (if not a special DVD sized scanner) that can scan an A5 sized page in a couple of seconds. Then I guess it depends on the software to make it faster to crop and save the image name.
The resolution I require is very minimal, I have been doing it at 100DPI just so I can get a plain 640x480 image suitable for a basic webpage.
If anyone has any advice or knows of any nice hardware that would help cut my 2 minutes down to maybe 15 seconds that would be great!
I do have a Canon 40D with WIFI setup and studio lighting but taking photos is a pain as I don't have a tripod and reflections bug me as I can never get the angles right to see the DVD clearly as you do with the scanner.
thanks for your input
