Approximate Purchase Date: 1 Month
Budget Range: $1,000 (Not afraid to go a bit over, but I'd like to stay under $1,200.)
System Usage from Most to Least Important: Gaming, Typical streaming, some animation in the future.
Parts Not Required: Monitor
Preferred Website(s) for Parts: Newegg, Amazon
Country of Origin: New York City, USA
Parts Preferences: by brand or type: None, as long as it is of quality.
Overclocking: Yes / in the future. Never OC'ed a PC, but I like having the option
SLI or Crossfire: Yes / in the future. Again, I like having the option.
Monitor Resolution:1920x1080 Dell 23" LED Display
Additional Comments: My first custom-built PC, I've done lots of research, but there are still some things I'm unsure of. I want to future-proof it as much as I can, but I get a little overwhelmed by the amount of components, even after narrowing my search.
Case- Corsair Obsidian Series 650D (CC650DW-1) ATX Mid Tower Computer Case $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
(I'm pretty much set on this case. I've looked at dozens and this one is by far my favorite. It's a bit pricey compared to others but I think I'm sticking with this case for many upgrades to come.)
MoBo- EVGA P67 SLI 130-SB-E675-KR LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188073
OR this one I saw in a another thread
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
(I'm open to any others that may be better/cost less)
GPU- EVGA 01G-P3-1561-KR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card $239.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130623
(Will this last on my current resulotion? I don't want a $500 card that puts out twice as much res if I don't need it.)
PSU- CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
(I've used different PSU calculators and they've given me 450W to 510W, what do you think? Also, i realize using another GPU in SLI will need more power, but i don't think I'll be doing that for a long time.)
CPU- Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K $219.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
(I don't know if I should stick with the stock fan/heatsink or get an aftermarket one.)
RAM- CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9 $28.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233141
HDD- Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
(Is getting an SSD on the side worth it?)
Opt Drive- ASUS Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner BW-12B1ST/BLK/G/AS - OEM $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252
Total- $1,100(ish), many components are undecided.
I'm buying the OS on Amazon. It costs pretty much the same everywhere and theres no real debate to it. I just want a rig that can handle anything I throw at it and that will last. I do plan on gaming (Battlefield 3) but I want it to have diverse capabilities and to be easily upgradable.
