Need for Speed: Carbon not running under Windows 10
LOLZpersonok
69
I purchased two games at Value Village a week or two back: Need for Speed: Most Wanted and Need for Speed: Carbon, both for PC. I didn't try them until now. I have installed both games on my computer, and Need for Speed: Most Wanted runs just fine, but Need for Speed: Carbon does not run at all.
A few days ago, I tried installing Need for Speed: Underground on my computer, but that didn't run either. I just assumed it was too old and left it at that. I think it's a little odd that Carbon doesn't work on my computer whereas Most Wanted does, as Most Wanted is an older game (even if by just a year).
Both Underground and Carbon, when a launch attempt is made, say "access denied: please login with administrator privileges and try again". When I try running both as an administrator, nothing happens, not even an error message. Trying to run either in compatibility mode for Windows XP, Vista, 7 or 8 don't work (same error as above), and trying to run it in compatibility mode with the aforementioned OSes as well as running as an administrator don't work. If it helps to know, I have the collector's edition of Need for Speed: Carbon.
I'm running a 64-bit edition of Windows 10 Home Edition, with a 2.30GHz AMD A10-4600M APU with AMD Radeon graphics (7660G and 7670M) and 8GB of RAM.
I remembered getting NFS Carbon to run on Windows 8.1 by copying the DVD contents onto the hard drive and running the launcher from that. I have not tried it yet in Windows 10, though. If I cannot get it to work in Windows 10, then I'll install it on Windows 8.1. But give it a try and see what happens.
I don't know if it will help NFS Carbon users, since it's meant to work for Pro Street users, but try renaming the executable (.exe) file in the game's folder... somehow it saved a lot of people :) I renamed mine to Prostreet but you can call yours whatever you want in theory... I'm probably wrong, but it's worth a try. Good luck!
I tried renaming the executable from NSFC to Need for Speed Carbon and tried running it both as an administrator or normally, and it didn't work either way.
I know that I took a long time to reply, I just never felt like doing it at the time that I saw your response. At this point, I am copying the game's files off of the CD. I will try launching the game from that new folder, and if it doesn't launch from there, I will uninstall the game and reinstall it from the files I copied onto the hard drive.
I tried that, and it didn't work, unfortunately.
Having the same issue here. Haven't had the time lately to try these solutions here but from what I can see they're not working either?
Compatibility mode does nothing whatsoever. I've tried it in compat. with all OS options without results. The exe doesn't react at all. No errors, no crashes. It does nothing.
I just find it so strange that Underground 2 and Most Wanted work perfectly but not Carbon of all things.
Can anyone confirm it runs fine in Win7?
I've ran it before in Windows 7 with no issues. I can confirm I'm having the same issues as LuigiFan. It doesn't crash, but it doesn't react. I ran the compatibility troubleshooter, it generated a test (Windows XP Service Pack 3) but when I tested it, nothing. No window comes up, nothing like that. This is after ripping the contents from the disc and placing it on my hard drive (PNY Optima 240GB SSD)
I'm convinced there's gotta be a way to make it work. If Most Wanted and Carbon both use the EAGL3 engine, and Most Wanted works, there's gotta be a way.
Unfortunately no one has found it yet, and apparently there's not a whole lot of interest to try to find it by the community. EA being incompetent doesn't exactly help either.
I just don't want to make a complete OS rollback to play this one game.
