Need For Speed Most Wanted 2012 not loading
Leandro Hawthorne
4
I have download need for speed most wanted 2012 and have installed it. but once am starting it, its just showing a white screen and wont start after that. i am having a 1 GB graphics card AMD 4300/4500 series, 2.3 GHz processor, and 4 GB RAM. i am running a windows 10 Pro Technical Preview.
install windows 8.1 pro 64bit OS...it should solve the problem....also check for vruses and malware...i guess that downloaded game has some defects.....
Well now your 'best' solution seems pretty silly in 2016. Similar problem here on legit Win10 build 10586. I don't really get any white screen. The game is 100% legit (it's "on the house" free right now from EA) Task manager shows it run for about a second then closes. Tried reinstalling several times, reinstalled Origin, no luck. System is an i5 3570k @4.5GHz on ASRock Z77 extreme4, 16GB RAM, 240GB OS SSD, 1TB storage HDD, 3 monitors w/main 30" 2560x1600. This game runs fine on my son's setup which is similar: 3570k @4.0GHz on ASRock Z75 pro3, 8GB RAM, 120GB OS SSD, 500GB storage HDD, 3 monitors with main 27" 1920x1080.
