Nexus X Sarwan :
when i play nfs rivals everything is 60 fps the cutscenes but the game when you have to drive it drops to 15 to 20 like slowmotion i have intel i7 4gb ram amd HD 8670M
What i7? What OS? What resolution? You're running minimum RAM.
In order to play Need for Speed Rivals on your PC, your system needs to be equipped with at least the following minimum specifications:
•Operating System: Windows Vista 32-Bit with Service Pack 2 and the KB971512 platform update
•Processor: AMD Athlon X2 2.8 GHZ or Intel Core 2 Duo 2.4 GHZ
•Ram: 4GB or more
•Free Hard Drive Space: 30GB
•Processor: AMD Athlon X2 2.8 GHz or higher; Intel Core 2 Duo 2.4 GHz or higher
•Graphics Card: AMD Radeon 3870 or higher; NVIDIA GeForce 8800 GT or higher
For the best Need for Speed Rivals experience, however, we recommend having a system equal to or better than than the following specifications:
•Operating System: Windows 8 64-bit
•Processor: AMD Six-Core CPU; Intel Quad-Core CPU
•RAM: 8GB
•Graphics Card: AMD Radeon 7870 or higher; NVIDIA GeForce GTX 660 or higher
•Graphics Memory: 3GB
Additionally, Need for Speed Rivals will support SLI-mode if your system is SLI-enabled.
Need for Speed Rivals will not support Driving Wheels. The Xbox 360 controller and Keyboard at the only supported input devices for Need for Speed Rivals.
