need for speed rivals pc performance........ plss help !!!
nsmd
74
is there any way of increasing performance of nfs rivals on pc
i tried using command line given in many forums but its no use....its still around 25-30fps on low settings and 720p
battlefield 3 and rivals use the same frostbite 3 engine
i'm able to bf4 smoothly at medium settings at 1600*900 then wat is the prob with rivals
y duz the performance suck so much on pc !!! 🙁
i really loved this game...jus wish that it ran fast on my pc(i3 3220..nvidia gt630...4gb ddr3 hyperx)
pls rply
thnk u
Try cleaning unwanted stuff with something like CCleaner. NFS rivals is just another very poorly optimized port(like bf4 was in the start..and still is not so much though)so you could end up waiting for patches to fix optimization.
Just because the game uses the same engine as another does not mean it will perform the same. Developers will utilize the same game engine for years, just increasing the complexity of the 3d models and the shaders and lighting effects used, meaning you will need more powerful hardware to run the games. Also the code running Battlefield 3 may be much more efficient than NFS.
Your PC is pretty low powered and just barely meets the minimum requirements for the game (your GT 630 The 8800 GT that is recommended.) You may want to consider upgrading your graphics card. A GTX 750 or 750 TI would give you a very good performance boost and will only run you a little over $100.
Fry's has a EVGA 750 superclocked for $99 this weekend. Get it and I bet you will be much happier with the performance of the game.
http://www.frys.com/product/8015094
