Need Gaming PC Build HELP!
Fwizzle
27
I've been trying to get all the parts together to create a new gaming pc for myself. I've spent hours looking for the best way to create a gaming pc. I found out about PCPartPicker. I started to use it and i think i have everything I need in order to create a pc. I do not want to spend over $400 on this PC. Please let me know if the parts I have are capable to run together. Thank you.
http://pcpartpicker.com/p/paO0
BreadWhistle
628
Oh my... that is.... much less than a desirable PC to even think about using. This is what I have whipped together for you...
As a matter of fact, I can't whip anything up for you as your budget is WAY to low. If it was $400 for the build, minus the monitors & windows, sure I could. But with it that likes only $220 for a gaming PC. With that amount of cash, you are looking at a very sluggish HTPC, not even anywhere close to playing much of any games at all.
Fwizzle
27
if the OS is removed, what do you recommend i get?
Fwizzle
27
I don't have my own monitor at the moment. I just have a laptop, so I need a monitor in the build, so what should i do to keep the build at 400 with the monitor included?
Fwizzle
27
so what parts should i get including the monitor for under or at $400?
Fwizzle
27
I did everything you said and now i have this http://pcpartpicker.com/p/pdL3
Is there anyway I could get a video card in there and keep it around $450?
milkshakez7z
279
CPU: Intel Pentium G850 2.9GHz Dual-Core Processor ($70.05 @ NCIX US)
Motherboard: Biostar H61MGC Micro ATX LGA1155 Motherboard ($29.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($24.99 @ Newegg)
Storage: Western Digital RE2 500GB 3.5" 7200RPM Internal Hard Drive ($48.40 @ Compuvest)
Video Card: HIS Radeon HD 7750 1GB Video Card ($94.99 @ Newegg)
Case: Cooler Master Elite 431 Plus (Black) ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Antec EarthWatts 430W 80 PLUS Certified ATX12V Power Supply
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.98 @ Outlet PC)
Monitor: Hannspree HL193ABB 18.5" Monitor ($79.98 @ Outlet PC)
Total: $394.37
(Generated by PCPartPicker 2012-11-24 11:28 EST-0500)
BreadWhistle
628
I know, but he is on a terribly tight budget, so I just thought I'd just use regular spec'd memory.
Fwizzle
27
I know that i should save my money in order to get a better video card, but what is a cheap and decent video card that I could use for a while until i have enough money for a better video card?
http://pcpartpicker.com/p/pdTt
Fwizzle
27
How does the PC specs made by milkshakez7z look to you? what do you think it is capable of running?
