Need GPU better than HD 5770
ss_56
334
15
18,795
Hi; I've been trying to play fallout 4 and i have everything set as low as possible but i'd like to get a card that will allow for high settings or at least medium and consistently good framerates at 1080p. Also want to overclock my old phenom II using the asus 'turbov' software so i ordered one of those 'hyper evo 212' coolers and hope that will be sufficient. I also ordered a samsung ssd drive to run windows and a couple games on.
I also just overclocked my old HD 5770 using the catalyst overdrive and my framerate did improve but i'd like a beefier GPU for $150 or less. The GTX 1050 ti has been suggested. I've always used AMD products so what would you guys say is the amd equivalent to the 1050 and should i stick with amd or does it matter? Most importantly, when i upgrade to an AM4 socket MB in the future, i'd like to put the new card in it.......and the gpu needs a display port like i use now which is a DVI-I....i think
i'd appreciate yall's input. thanks
MOTHERBOARD - M4A89GTD PRO/USB3
CPU - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
PSU - Corsair RM 650-Watt
MEMORY - PNY Optima 16GB (4x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
GPU - XFX Radeon HD 5770 (Juniper XT) DirectX 11 HD-577A-ZNFC 1GB 128-Bit GDDR5 PCI Express 2.1 x16
CASE - Corsair Obsidian D450 Mid-Tower
HDD - WD ST1000DM003-9YN162
The rx560 is a good bit faster than the old HD5770. So atleast get the rx560 or 1050ti. If you could wait for the rx570 prices to rebound would be the best option.
http://gpu.userbenchmark.com/Compare/AMD-RX-560-vs-AMD-HD-5770/3926vsm7752
Video Card: Sapphire - Radeon RX 560 2GB PULSE Video Card ($113.99 @ SuperBiiz)
Total: $113.99
Generated by PCPartPicker 2017-08-03 18:38 EDT-0400
or
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card ($144.99 @ B&H)
Total: $144.99
Generated by PCPartPicker 2017-08-03 18:40 EDT-0400
"If you could wait for the rx570 prices to rebound would be the best option."
I'm seeing nearly twice the power on benchmarks favoring the 570 over the 560 so thanks for that heads up! think i'll keep saving my pennies and get the 570. thanks
