Need Graphics card Arma 2 (dayz) up to 200pounds max
westygaming
15
hey i have a
XFX R7770 GHOST
im looking for a new one to run dayz at 60fps or more. im looking to spend up to 200 pounds can anyone help me out pleases
A GTX 770 does just fine in ArmA2/DayZ and ArmA3 (surprisingly better here). The 280X performs just as well. If you can get your hands on one, get a Z77 and OC that 3470 a little. I've read that you can get it up to 4.0GHz (Intel boost) on ASRock Z77 boards. It'll serve well stock with a 770 or a 280X, though at that point OC'ing that i5 will show noticeable gains as well.
Well yes considering the 3470 has a locked multiplier since it's a non-k, you still have the base clock, which you won't need the Z77 for, still doable on a B75. And yeah 600w is pushing it just a little on a 280X or 770. Unless you plan on going with a new PSU soon, go with the 760. Medium to high settings, which will still look nice at 1080p.
If you plan on expanding with more cards (aside from another GPU) a 750w will do great. If you want another GPU, go for a 850w. And yes your B75 motherboard should have an overclock option for the base clock (BCLK) which not only will overclock your CPU a tiny bit, but also your RAM.
Corsair CX750M: http://www.newegg.com/Product/Product.aspx?gclid=CPTh65Xeyb0CFQqEfgodFL4AMQ&Item=N82E16817139051&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Power+Supplies-_-N82E16817139051&ef_id=U0ARZwAABOoLZ77H:20140405161123:s
Safest for your current PSU.
Agree with Rolli59: The R9 280X is a power hungry card and I'd hate to see your system get damaged by stressing the existing PSU too much, so the GTX760 is your best option unless you add a better power supply to the upgrade.
If you DO decide to ugrade the PSU, a decent 600W unit would drive the current system (plus R9 280X) easily enough and I'd personally look for something a little more upmarket than the CX series. A Few Good Names: Corsair (not the CX!), Silverstone (not the Strider Essential), Antec, Seasonic, EVGA and XFX.
Have a look at some card reviews, Toms, Guru3D and Techpowerup are all good places to look because they compare plenty of cards in their benchmarks, that way you can see if the extra cost of a PSU+R9 280X is worth it over the simpler GTX760 upgrade.
Personally, I don't think swapping motherboards will help too much, the CPU is not likely to overclock enough to justify the cost and time required.
If you're getting a PSU now, you may as well just get the 600w or a 650w from EVGA and later on get yourself a GTX 760 or R9 270x or whichever Radeon equivalent proves best in benchmarks, when you can afford it. Keeps under the 200 pound limit I'm guessing?
