Need graphics card compatable with HP Pavilion 500-336
I have not, but I do things of the same class very often. if the power supply does not have a six pin VGA power cable and is at least 350 watts get a GTX 750 ti, if you have a single six or eight pin get a R9 270 non x or if you really want a 960 but that would be a bit overkill. the card will be compatible, just make sure to measure out the space in your case before buying a card as a big card that does not fit is a real annoyance
