Hi! I created this build but I'm not sure what graphics card to use on it.
I though maybe the Sapphire Radeon R9 270X 2GB Tri-X Toxic Video Card, but I'm not sure.
I needed sugestions for a graphics card under $240-$250 tops, I don't care about brands or anything, just the best for gaming.
I would like to overclock too, so I can get the best performance.
Build without graphics card: http://pcpartpicker.com/p/bdPNyc
Thank you
P.S.: It says that the sapphire r9 toxic won't fit on the case, also wanted to know if i should worry about that or not.
Thank you
