Need guidiance for two cables.
Egonslosse
18
I have two cables that still need to be wiered up, buy i have no clue as to where they should go.
These are the wires i am talking about: http://postimg.org/gallery/3eayt0e62/bd4c45aa/
It is the white one and the black one, the long wire i am holding up is still conected to the old mobo, can i cut that off? Both the black and white wires seem to come from above the CDROM drive..
Edit: the black wire has 4 connectors at the bottom and two on the top it looks like this:
ooxxx
oooo-
X representing an open but empty slot O being an open slot with connectors - being closed.
The white wire is just one line like this: oooox
This is what the connector on the mobo and the front of my case looks like: http://postimg.org/gallery/f3uv9tr8/f524f374/
Thanks a thousand times for any help!
The small black connector with one pin missing looks like the USB header. Just look for the corresponding slot on that one and the molex one, the one with 4 pins should go in the CD Drive if it's old but if not, you can leave it out.
- Sam
I can assure you that they both come from the front panel and i already have two cables in both of the USB slots and they are also correct these cables should have something to do with the booting button and si on..
