[SOLVED] Need Hard Drive Purchasing Advice
Oct 28, 2020
5
Hi, my son has an old Alienware computer. I've upgraded the graphics card and now it's in need of a third hard drive. What he has is:
Alienware Aurora ALX + TactX Headset
317-4088
Overclocked Intel Core i7 930 QC (3.36GHz, 8MB Cache)
Hard drives:
1TB RAID 0 (2x500GB) SATA II (3Gb/s) Solid State Hybrid, 7200RPM
Any help is appreciated. I'd like to keep it under $200 if possible. Thanks!
~Vikki
Thanks for the info, I should've asked if it's possible to add a third hard drive as the computer came with two. Or do I need to go with an external?
Likely, you can.
Most motherboards will have 4 or more sata device slots.
A photo of the motherboard would verify that such slots are available.
Then, your power supply will need an available sata power cable. Adapters can supply this if necessary.
Lastly, you need a place to physically install a drive.
If the extra drive is a ssd, they can go almost anywhere.
Again, a photo of the drive space with the covers off could help.
In a video, I saw, it looked like you would be ok, but I have no idea if the video was of the same pc as yours.
317-4088
Hard drives:
~Vikki
You could get a 1tb ssd and if you want more storage get a 2tb hdd
Ssd;
https://www.amazon.com/Crucial-MX50...500+ssd&qid=1603897894&sprefix=1TB+MX5&sr=8-3
It is not clear to me exactly what your unit looks like.
Can you provide a link?
I think your problem is relatively simple.
I am guessing that windows is installed on the raid-0 device.
Raid-0 combines two devices into one logical device and writes data alternately on each.
In theory, it can double the data transfer speed.
In actuality, raid-0 is worthless and confers no benefits outside of synthetic benchmarks.
For added capacity, buy a 1tb samsung 860 evo ssd. It will cost about $120.
Use the free samsung ssd migration app to copy your windows C drive from the raid-0 array to the 860 evo.
When done, boot from the new ssd and reformat the two old devices into two individual devices, giving you the extra capacity you want.
For about $250, you could buy a 2tb 860 evo and have everything on a single larger C drive.
You can download the ssd app and instructions here:
Not sure how to post a link from the tablet. It is win 7, bought in 2011 and the graphic card is now Sapphire PULSE Radeon RX 580 8GB
224-7420
317-4088
317-3195
12GB Triple Channel 1333MHz DDR3
330-6078
Alienware TactX Keyboard, US
320-8253
21.5" Alienware AW2210 OptX Full HD Gaming Monitor, 21.5" viewable image size
320-1646
Nvidia GeForce GTX460 Dual
421-1308
Dell V515w Printer Driver
342-3040
A 2TB HDD is exactly the same size as a 1TB.
And no, RAID is not needed or wanted. That 1TB SSD is lots faster than 2x HDD in RAID 0.
Likely, you can.
