Need Help - $1000 Work/CAD build
ampddbi
I've been looking to finally build another desktop as my laptop isn't really cutting it for me anymore. I'd need to be able to run CAD (SolidWorks mostly) as well as Photoshop and the occasional game (nothing too strenuous). I'm looking to spend around $1000 for hardware (processor, motherboard, PSU, RAM, HDD, graphics, case) although I'm not opposed to spending a bit more if the gains are worth it. I've been out of the desktop game for a while so I'm not too familiar with the current options. Would the new AMD Bulldozer be worth it, or should I stick with Intel? I'd also like to be able to put a separate RAID setup together in the near future to use as a home file server, so if it would be at all possible to incorporate that it would be an added bonus.
Thanks
ampddbi
Sorry, must have missed that.
Approximate Purchase Date: Now through 2 months
Budget Range: 1000 (maybe more, see description)
System Usage from Most to Least Important: 3D CAD, Photo editing, file server, watching movies
Parts Not Required: Monitor, speakers, keyboard, mouse
Preferred Website(s) for Parts: newegg.com, amazon.com, microcenter.com
Country of Origin: USA - New Jersey
Parts Preferences: no preference
Overclocking: Maybe, probably not
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200
Additional Comments: I've been looking to finally build another desktop as my laptop isn't really cutting it for me anymore. I'd need to be able to run CAD (SolidWorks mostly) as well as Photoshop and the occasional game (nothing too strenuous). I'm looking to spend around $1000 for hardware (processor, motherboard, PSU, RAM, HDD, graphics, case) although I'm not opposed to spending a bit more if the gains are worth it. I've been out of the desktop game for a while so I'm not too familiar with the current options. Would the new AMD Bulldozer be worth it, or should I stick with Intel? I'd also like to be able to put a separate RAID setup together in the near future to use as a home file server, so if it would be at all possible to incorporate that it would be an added bonus.
This build allows you to add another one of those cards later on for SLI.
http://www.amazon.com/Cooler-Master-Tower-Case-RC-912-KKN1/dp/tags-on-product/B003ZM7YTA $59.99 & this item ships for FREE with Super Saver Shipping
Cooler Master HAF 912 Mid Tower ATX Case (RC-912-KKN1)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049 $94.99 - $69.99 after mail-in rebate FREE SHIPPING $10 off w/ promo code EMCKBJH49, ends 8/14
Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.714153 $190.98 FREE SHIPPING
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
http://www.microcenter.com/single_product_results.phtml?product_id=0354587 $285 (Walk In Only)
Core i7 2600K LGA 1155 Boxed Processor
http://www.amazon.com/Cooler-Master-Hyper-Sleeve-RR-B10-212P-G1/dp/B002G1YPH0/ref=dp_cp_ob_pc_title_1 $28.57 & this item ships for FREE with Super Saver Shipping
Cooler Master Hyper 212 Plus 120mm Sleeve CPU Cooler, RR-B10-212P-G1
http://www.amazon.com/Samsung-Spinpoint-Cache-Desktop-HD103SJ/dp/B001U3S5S0/ref=sr_1_1?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1313196236&sr=1-1 $59.79 & this item ships for FREE with Super Saver Shipping
Samsung 1 TB Spinpoint 7200 RPM 32MB Cache SATA 3.5 inch Bulk/OEM Desktop Hard Drive HD103SJ
http://www.amazon.com/Sony-SATA-Internal-Drive-AD-7260S-0B/dp/B003MRHOQG/ref=dp_cp_ob_pc_title_2 $19.99 Free Standard Shipping (3-5 days)
Sony 24X SATA Internal DVD+/-RW Drive AD-7260S-0B - Bulk (Black)
http://www.amazon.com/EVGA-GeForce-PCI-Express-Graphics-01G-P3-1460-KR/dp/B0050I1PHO $184.88 & this item ships for FREE with Super Saver Shipping
EVGA GeForce GTX 560 1024 MB GDDR5 PCI-Express 2.0 Graphics Card 01G-P3-1460-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986 $94.99 FREE SHIPPING
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Total: $1,019.18 *not including tax and mail in rebates
http://www.gigabyte.com/products/product-page.aspx?pid=3892#ov <------GIGABYTE GA-Z68XP-UD3 Motherboard
http://www.anandtech.com/show/4083/the-sandy-bridge-review-intel-core-i7-2600k-i5-2500k-core-i3-2100-tested/11 <---- Review / benchmarks of HD 3000 graphics, Lucid Virtu, etc...
http://www.javelin-tech.com/blog/2011/01/solidworks-multi-threading/ <---- SolidWorks takes advantage of hyper threading hence the 2600K in this build.
http://www.tomshardware.com/reviews/z68xp-ud3-dz68db,2980.html <----- Review of that board
http://www.anandtech.com/bench/Product/203?vs=287 <----- AMD Phenom II X6 1100T BE vs Intel Core i7 2600K benchmarks
http://www.tomshardware.com/reviews/core-i7-990x-extreme-edition-gulftown,2874.html <----- $1,000 Intel Core i7-990X Extreme vs $330 Intel Core i7 2600K Sandy Bridge
*Sandy Bridge reviews down below
http://www.tomshardware.com/reviews/sandy-bridge-core-i7-2600k-core-i5-2500k,2833.html
http://www.anandtech.com/show/4083/the-sandy-bridge-review-intel-core-i5-2600k-i5-2500k-and-core-i3-2100-tested
http://www.legitreviews.com/article/1501/1/
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=622&Itemid=63
http://www.guru3d.com/article/core-i5-2500k-and-core-i7-2600k-review/
