Need Help 1ST Time Rig
Zuzay
4
Just want to see if this rig i built is good for playing fps at normal to high settings. Please send feedback to see if there are better options and cheaper ways of going about things
Gaming Chasis: CYBERPOWERPC X-Saber w/ USB 3.0, Large Side Panel Window (Black with Red LED)
Laser Engraving: None
Neon Light Upgrade: None
Extra Case Fans: Default case fans
Noise Reduction Technology: Sound Absorbing Foam on Side, Top And Bottom panels
CPU: Intel® Core™ i5-4690K 3.5 GHz 6MB Intel Smart Cache LGA1150 (All Venom OC Certified)
Freebies: FREE! INTEL Q2 2015 GAME BUNDLE (FREE games: Counter-Strike: Global Offensive, FINAL FANTASY® XIV: A Realm Reborn, GRID Autosport, World of Tanks, & LEGO® Minifigures Online.)
Performance Tuning Protection Plan by Intel: None
Venom Boost Fast And Efficient Factory Overclocking: Pro OC (Performance Overclock 10% or more)
CPU / Processor Cooling Fan: Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Dual Standard 120MM Fans (Push-Pull))
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: GIGABYTE Z97X-SLI ATX w/ Intel GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI, 1 x M.2, 1 x SATA Express, or 6x SATA 6Gb/s (Extreme OC Certified)
NFC: None
Intel Smart Response Technology: None
RAM / System Memory: 16GB (8GBx2) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
Video Card: NVIDIA GeForce GTX 750Ti 2GB GDDR5 PCIe 3.0 x16 (Single Card)
Freebies: None
Power Supply: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
M.2 SATA SSD: None
INTERNAL PCI-E SSD CARD: None
Hard Drive: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
Secondary Hard Drive: None
Hard Drive Cooling Fan: None
External Storage: None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
External Optical Drive: None
WiDi Router: None
Internal Wireless Network Card: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
LCD Monitor: None
Cables: None
Speakers: None
Internal Network Card: Onboard Gigabit LAN Network
Keyboard: AZZA Delta Gaming Keyboard w/ Anti-Ghosting & red backlight
Mouse: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
Mouse Pad: Corsair Gaming MM200 Mouse Mat - Standard Edition PN:CH-9000079-WW
Headset: None
Headset Hanger: None
Gaming Gear: None
Fan Controller/Temperature Display: None
Internal USB Expansion Module: None
External Wireless Network Card: None
Wireless Routers/Hubs: None
Docking Station: None
Bluetooth: None
Flash Media Reader/Writer: None
Video Camera: Creative Live! Cam Chat HD 720p w/ Noise-Canceling Microphone
Gaming Tablet: None
Power & Surge Protection: None
USB Hub & Port: Built-in USB 2.0 Ports
External USB ADAPTER: None
Operating System: Windows 8.1
Media Center Remote Control & TV Tuner: None
Office Suite: McAfee AntiVirus Plus
Games: None
Ultra Care Option: None
Service: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
Rush Service: Standard Process Time: Ship within 8 Business Day
No no no. You can't be sure what PSU you'll get.
I strongly suggest you buy the components yourself and build it yourself, you will save money.
Please also build this on http://pcpartpicker.com, I for one don't want to have to dig through that wall of text that details the cheapo 'freebies' you're getting.
If you insist on using cyberpower, here's my advice.
Get the XFX 550w PSU, they have that available and it's a great unit. You have too much processor and very little GPU. Your GPU should cost 2x as much as your processor in a gaming build. Go for a GTX 960 or R9 280 at the least. Drop down to an i5-4460 with stock cooling on the cheapest motherboard they have like a B85. You don't need 16gb of memory.
Just because I'm a cool guy i went and priced your machine, looks like $968 with OS, mouse, keyboard, and a webcam. I'm going to skip the webcam and get you a full build for $950 that will stomp cyberpower. You just have to spend an hour putting it together.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($189.95 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($69.99 @ SuperBiiz)
Memory: Mushkin Radioactive 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card ($303.99 @ Newegg)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($51.98 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($13.98 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($89.95 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($28.99 @ NCIX US)
Total: $951.30
Generated by PCPartPicker 2015-05-09 13:48 EDT-0400
