Need help about CPU upgrade ASUS F80S laptop
sinplayer
Hi,
I want to upgrade my ASUS F80S' CPU whicih Core 2 Duo T5750. Here is my CPU-Z report. It says my motherboard has Sis 671FX/DX/MX chipset and my CPU is Socket P (478). What is the fastest CPU I can install? Please help! I'm gonna be blind because of googling since last thursday.
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Mobile Core 2 Duo T5750
Codename Merom
Specification Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz
Package (platform ID) Socket P (478) (0x7)
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
Core Speed 2000.5 MHz
Multiplier x FSB 12.0 x 166.7 MHz
Rated Bus speed 666.8 MHz
Stock frequency 2000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 12.0x
Max VID 1.250 V
Chipset
Northbridge SiS 671/FX/DX/MX rev. 00
Southbridge SiS 968 rev. 01
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 3072 MBytes
Channels Single
Memory Frequency 333.4 MHz (1:2)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Monitoring
Mainboard Model F80S (0x00000101 - 0x00002818)
DMI
DMI BIOS
vendor American Megatrends Inc.
version 220
date 11/06/2009
ROM size 1024 KB
DMI System Information
manufacturer ASUSTeK Computer Inc.
product F80S
version 1.0
serial NF1S8822260166
UUID {DD812F4F-DC4E-B380-7880-0022158E55D3}
DMI Baseboard
vendor PEGATRON CORPORATION
model F80S
revision 1.0
serial BSN12345678901234567
DMI System Enclosure
chassis type Notebook
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz
clock speed 2000.0 MHz
FSB speed 167.0 MHz
multiplier 12.0x
According to my search abilities it seems you may already have the fastest processor that your computer will accept. Socket P is a discontinued platform and I wouldn't advise putting any money into it.
But, in my searches, I've find out that, my motherboard can work at 800 MHz. FSB Actually I've find a T8100 for $20, used. Doesn't it worth to try?
I have the same laptop as you bro and i am fully aware that the core 2 duo is all its going to take. You need a new computer. If you like upgrading computers i suggest you get a desktop computer.
