[SOLVED] Need help about my first build
Feb 13, 2019
7
Ok so im building my first pc this september so i wanted to know if i should change anything or leave it be.
CPU: Ryzen 5 2600
GPU: GeForce GTX 1660 Ti OC 6G (Gigabyte) or MSI GeForce GTX 1660 Ti 6GB GDDR6 Ventus XS OC (I can get them for same price so i was wondering MSI or Gigabyte)
RAM: 2x CORSAIR 8GB Vengeance LPX DDR4 3000MHz CL16
MOBO: B450 TOMAHAWK
SSD: CRUCIAL 500GB MX500 M.2
PSU: EVGA B1 600W
So i was wondering about the GPU question i said, is motherboard going to be ok and will it support overclocking to 3.9 or 4 (if not whats the cheapest solution so i can do it in future), is SSD ok, is PSU enough and can it take overclocking? I already have good cooler for overclocking and case with 3 fans so thats good.
Thanks!
logainofhades
Not bad, but made some changes, to get you an even better PSU.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($129.99 @ Amazon)
CPU Cooler: Deepcool GAMMAXX 400 74.34 CFM CPU Cooler ($19.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard ($114.99 @ Amazon)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory ($67.99 @ Newegg)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive ($59.99 @ Amazon)
Video Card: MSI GeForce GTX 1660 Ti 6 GB VENTUS XS OC Video Card ($269.99 @ Amazon)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($79.90 @ Amazon)
Total: $742.84
Generated by PCPartPicker 2019-08-22 12:48 EDT-0400
I would go with a better PSU. EVGA makes some good PSUs, but the B1 is not very good. I would suggest getting a quality 550 watt PSU from Corsiar, or Seasonic. A malfunction in the PSU can damage your hardware, so you want a good one.
Additionally, I would look at the AMD 3600 if you can afford it. They are a pretty good price and have a decent bump over the 2600.
Here is a base seasonic model that would be the starting point.
PCPartPicker Part List: https://pcpartpicker.com/list/2v8kNQ
Power Supply: SeaSonic S12III 550 W 80+ Bronze Certified ATX Power Supply ($55.99 @ Amazon)
Total: $55.99
Generated by PCPartPicker 2019-08-22 10:06 EDT-0400
Feb 13, 2019
7
Total: $55.99
will Seasonic S12 II 620W be good enough i see you said S12 III what about II because i can find that one close to me
logainofhades
Total: $742.84
