Need help about my tv vga port
ishaankaushik
BANNED
Sep 7, 2017
133
I tried to connect my xbox 360 with my tv's VGA port but it displayed black screen when switched to pc mode.So I wanted to ask that if it is my converter's fault or my tv's VGA port?thanks for any help!
Is it an active adapter or not? If not then thats your problem since a digital signal cannot be converted to an analog signal without a bit of help.
How are you converting the cable from the xbox's analog video out or hdmi?
I am using HDMI to VGA converter.
