Hello Fellas
I have a issue on my laptop
The model is
Gigabyte P35g V2
and spec is
4710HQ, 8GB RAM, GTX 860M, SSD + Windows 10
The all driver versions are latest except Intel MEI
My problem is the laptop does not shutdown completely.
If I press shutdown icon or Power button, display turned off but LED and cooler is not.
I read this post but not works well
http://h30434.www3.hp.com/t5/Notebooks-Archive-Read-Only/Sleep-and-Shutdown-issues-after-upgrading-to-Windows-10/td-p/5177663/
I found few facts,
1. Intel MEI is not problem
2. BIOS restore is not helpful
3. I made sure turned off hibernate mode and fast start option
4. Format is not helpful because I formated several times and the symptom is always showed up
5. "BUT If I turn off my external graphic card(GTX860M) from BIOS, it completely shutdown."
Please help this problem if you got a answer or feel free to ask me bout more info what I didn't post it.
Thank you very much.
The model is
Gigabyte P35g V2
and spec is
I found few facts,
