Need Help about ZOTAC GTX 1070 AMP Extreme
Owais786
Commendable
Jul 26, 2016
I am planning to Buy ZOTAC GTX 1070 AMP Extreme but it look so heavy and bulky it might bend my PCIe Slot??? Any suggestion to protect my PCIe Slot??
MY RIG:
Dell S2216H Monitor
GIGABYTE GA-Z97-D3H MotherBoard
4th Generation INTEL i5 4690K 3.5 Ghz
16 GB CORSAIR Vengeance DDR3 Ram
WD Blue 1TB Hard Disk
COOLER MASTER Hyper 212x CPU Cooler
CORSAIR VS650 Watt Power Supply
COOLER MASTER HAF 912 Case
Should be more than fine. It has a back plate too which is nice.
But again, it should be fine. It may sag a bit on the back corner, but nothing that should break your PCI slot. As long as you tightly secure it on the bracket, you are good.
you should be fine, it wont bend, i promise you, and the people saying that a bent pcie slot affects preformance is like the extreme cases where the pcie slot is littrally going to fall of the mobo, and btw pcie armor doesnt do jack
