Hi There
I have a issue
PS3 doesn't see AD-HOC networks created by my laptop wich is running Windows 7.
I Think i might have a solution and hope someone could clarify
So the main point of entry for the internet will be by my laptop which gets it from the 3G usb dongle, then i want to run a straight Ethernet cable to the adsl router(which provides wifi aswell) and then connect my PS3 onto the Wifi created by the router.
I know i can use a crossover cable between the laptop and PS3 but would like this feature instead
Will it work?
I have a issue
Will it work?
