Question NEED: Help/advice on building my PC.
Dec 4, 2019
4
Hello you,
Thanks for reading and maybe helping me out.
I am looking to build a new PC and I'm looking for some thoughts and advice on the following set-up:
  • CPU: i7-9700K (or should I go for i5-9600K)
  • MOBO: MSI MPG Z390M GAMING EDGE AC - is µATX (or should I go for MSI MPG X570 Gaming Plus)
  • GPU: Gigabyte GeForce RTX 2070 Super GAMING OC 3X 8GB (or should I go for any other RTX 2070 Super)
  • SSD: Samung 970 EVO, 500GB
  • RAM: Corsair LPX 32GB DDR4-3000
  • CPU-cooler: Noctua NH-D15
  • PSU: Corsair RMx850
  • CASE: Corsair Crystal 460X RGB (or any other advice)
I am going to use this PC for gaming - mostly shooters.
Again, thanks for reading and helping me out!
Lutfij
If you go for the X570, you won't be able to use that Intel processor. You will need to look at AMD's Ryzen 3000 series processors.
The build as is, is alright. I don't know how much you're paying for it but something tells me we could probably tailor a better build with AMD's Ryzen processor in there.
List your location, your budget and your preferred site for purchase. Better yet, read through this thread and stylize your post accordingly with the additional information.
Dec 4, 2019
4
I like to build a PC - €2000 ($2200).
I can't assemble it myself.
Suggest me for the following please:
  • CPU:
  • MOBO:
  • GPU:
  • SSD:
  • RAM:
  • CPU-cooler:
  • PSU:
  • CASE:
Approximate Purchase Date: ASAP
Budget Range: €2000 ($2200) - with assemble & shipping
System Usage from Most to Least Important: Gaming
Are you buying a monitor: No, I have a BENQ XL2411
Parts to Upgrade: New build
Do you need to buy OS: Yes - need new Windows
Preferred Website(s) for Parts: https://vgcomputers.be/ and https://www.alternate.be/
Parts Preferences: None
Overclocking: I won't do it myself, so maybe standard - not too much noise btw
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: I don't need a lot of bling - not to loud (using CS:GO and PUBG - Battlefield in the future)
And Most Importantly, Why Are You Upgrading: My older PC is getting slow - lagging.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor (€353.95 @ Bytes At Work)
Motherboard: MSI MPG X570 GAMING EDGE WIFI ATX AM4 Motherboard (€231.95 @ Bytes At Work)
Memory: G.Skill Trident Z Neo 16 GB (2 x 8 GB) DDR4-3600 Memory (€132.95 @ Bytes At Work)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive (€69.99 @ Paradigit)
Storage: Intel 660p Series 2.048 TB M.2-2280 NVME Solid State Drive (€239.00 @ Paradigit)
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive (€103.89 @ Alternate Belgium)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card (€488.95 @ Bytes At Work)
Case: Fractal Design Define S2 ATX Mid Tower Case (€129.85 @ Alternate Belgium)
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Fully Modular ATX Power Supply (€99.90 @ Paradigit)
Operating System: Microsoft Windows 10 Home OEM 64-bit (€117.95 @ Bytes At Work)
Total: €1968.38
Generated by PCPartPicker 2019-12-04 15:04 CET+0100
The stock Ryzen CPU cooler is just fine so you save money there. The smaller SSD is for OS/Applications and the larger for games. The HDD is for movies, music, etc...
Reactions: Encryption+
Flayed
Upstanding
Oct 8, 2019
440
59
390
28
CPU Cooler: be quiet! Dark Rock Slim CPU Cooler (€65.95 @ Bytes At Work)
Motherboard: ASRock X570 Steel Legend ATX AM4 Motherboard (€257.08 @ Newegg Belgium)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive (€128.89 @ Alternate Belgium)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive (€123.89 @ Alternate Belgium)
Case: Fractal Design Define C ATX Mid Tower Case (€89.85 @ Alternate Belgium)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€112.90 @ Paradigit)
Total: €1872.36
Generated by PCPartPicker 2019-12-04 15:57 CET+0100
Total: €1968.38
Is that ram compatible with the board?
ScrewySqrl
Champion
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard (€176.95 @ Bytes At Work)
Memory: G.Skill Trident Z 32 GB (2 x 16 GB) DDR4-3733 Memory (€339.86 @ Newegg Belgium)
Storage: Western Digital Red Pro 4 TB 3.5" 7200RPM Internal Hard Drive (€183.89 @ Alternate Belgium)
Video Card: Inno3D GeForce RTX 2070 SUPER 8 GB JET Video Card (€593.95 @ Bytes At Work)
Case: Fractal Design Focus G ATX Mid Tower Case (€54.94 @ Alternate Belgium)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply (€77.95 @ Bytes At Work)
Total: €2020.49
Generated by PCPartPicker 2019-12-04 18:57 CET+0100
Go to DELL Site and Select New Aurora Alienware Desktop. Under that select the one priced at 1,849 and configure it as per spec in below provided image
If you don't plan on building one your self this is the best you can get for that budget prebuilt. Big hit on performance compared to what you can get when you assemble it your self.
Here is the list:
Motherboard: MSI B450M BAZOOKA V2 Micro ATX AM4 Motherboard (€85.99 @ Paradigit)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory (€77.89 @ Alternate Belgium)
Video Card: Gigabyte GeForce RTX 2080 Ti 11 GB WINDFORCE Video Card (€1282.99 @ Alternate Belgium)
Case: Fractal Design Core 2300 ATX Mid Tower Case (€54.94 @ Alternate Belgium)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€124.85 @ Alternate Belgium)
Total: €2104.50
Generated by PCPartPicker 2019-12-05 13:57 CET+0100
Price is same but performance it is around 50-60% improvement over Alienware. And of very high quality.
Dec 4, 2019
4
Hi guys,
I've put together the PC that I want on www.alternate.be. This because I don't like to buy these parts apart, so I am looking for someone to assemble them and having some aftersales support.
After everything the price of these parts assembled is €2600 - I want your advice on this build. Where could be the bottleneck, what is an overkill for other parts, ...
MOBO: GIGABYTE AORUS X570 AORUS PRO
CPU: AMD Ryzen 9 3900X socket AM4
COOLER: Noctua NH-D15 cpu-koeler
RAM: Corsair 32 GB DDR4-3200 GPU:
GIGABYTE GeForce RTX 2080 SUPER GAMING OC 8G V2
PSU: Corsair RM850X, 850 Watt
SSD: Samsung 970 EVO Plus, 500 GB
OS: Microsoft Windows 10 Home 64bit
Thanks a lot!
