My desktop case have a window panel on its side, the case is SAMA E-Sport 2. i want to replace that panel with a 20cm fan for additional cooling.
I have already installed 2 12cm fans at the front for intake, 1 up and 1 rear for exhaust. I have measured the fan and the panel, they loosely fit, with the panel dimensions approximately 21x22cm, so can anyone here give me advice on this, how and what needed to be done to make the fan fit nicely with the panel, i tried using additional plastic panel and rubber pieces to fill the space but it doesn't work as they unable to hold the fan , i need something that can hold the fan tightly with the case.
Oh, and the fan is Cooler Master Masterfan MF200R RGB.
www.coolermaster.com
MasterFan MF200R RGB
The MasterFan MF200R RGB, a new member of the MasterFan family, provides a specific air cooling solution ideal for chassis in-take fans. Designed for Builders with RGB-enabled PCs, you can feel the flow with full color fun, and perfect match your PC's theme. The MF 200R RGB with milky color fan...
