Need Help/advice Upgrading my PSU
Pwnzor4life
My computer is an HP Compaq dc5700 small form factor. My current PSU has a 240w maximum. The graphics card that i'm upgrading to requires a 300w minimum. The problem is that my PSU is shaped oddly, so the PSU itself can fit inside of the case without hitting other components. A link to a picture of what it looks like is below
http://
Does anyone know of a PSU that's at least 300w that i can put into an HP Compaq dc5700 small form factor? Thankyou
You didn't post a budget, here are some choices:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151063
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104075
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151089
They aren't odd shaped, but...
They aren't odd shaped, but all are designed for small form factors, you'll need to actually measure the
space available and compare to the dimensions of these PSU's.
