Hello,
Builds link. Small differences: the case is Antec GX300, PSU is a High Power Bronze Element II 600.
I have already ordered/had delivered the 4590 Haswell build (two of them actually, one is for my wife and it's identical except video card, which is a 960 Strix) but I started to have second thoughts after I read up reviews and forums (should have done it before). So I started putting together the 6600k build, which for now is only hypothetical but I can make it happen with some bother if I return/replace what I bought.
Disregard the prices, here in Romania they are very different: $1275 for Skylake and $1055 for Haswell. Their primary use will be gaming with some coding on the side. I probably won't upgrade them along the way, just buy new after 5 years or so.
To make matters worse, I just discovered that GX300 only fits a 140mm height CPU cooler and this is bad as CPU coolers are expensive around here (almost $40 for the Cooler Master 212).
Now the questions/options:
1. Is the Skylake build worth the price difference? I know it's got a more expensive Z170 MB, PSU and cooler (must replace this, see 3.) but if I'm not overclocking would be kinda pointless to buy it so I think it needs them. Also, is Gigabyte GA-Z170X-Gaming 3 preferable? They are about same price here and Gigabyte is easier to get.
2. Will overclocking the Skylake 6600k to 4.5Ghz help in any way with games?
3. And are there any good, cheap and under 140mm coolers comparable to Cooler Master 212 which are usable for this? (my wife's only condition was that the cases are the same and since one is already unpacked and I threw the box, might not be able to return it).
4. The store I might buy 6600k from gives a free cooler with it: ID-Cooling SE 903 which I assume is mediocre but can be perfectly fine if I don't overclock, correct? And I might still keep the Z170 MB in case I overclock after some years.
5. Would a lesser Skylake build make sense? (6600 3.3Ghz, Gigabyte H170 D3H). If I keep the stock Intel cooler, it would cost around $1155, right in the middle of the two). And, is the Intel cooler OK for non overclocking?
6. Would a 4690k make sense? (with a Gigabyte Z97-D3H) it would go about $1120 but again I will have the 140mm cooler problem
7. I could keep the 4590 as I have with the Intel stock cooler (which I assume it works OK)
Damn, and I thought I could make this short. My personal preference would be 6600k Skylake, of course and I can actually afford it, but returning the components, waiting for others and paying extra would kinda be a bother.
Anyways, I would REALLY appreciate some opinions/advices as the return date for my components is pretty near now and I used huge amounts of time just thinking/reading about it.
