H hacker 62 Honorable Jun 28, 2013 4 0 10,510 Jul 14, 2013 #1 my computer is saying it is only using 43% is that normal i have 8 gig installed in the computer its self can any one help please
Solution Dark Lord of Tech Jul 14, 2013 Yes it's normal 8 gigs is a lot of ram!!!!!!!!The system uses what it needs.Not using it all in this case is good, plenty to spare.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jul 14, 2013 Solution #2 Yes it's normal 8 gigs is a lot of ram!!!!!!!!The system uses what it needs.Not using it all in this case is good, plenty to spare. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jul 14, 2013 #3 Don't forget to choose a Best Solution when opening a question thread , the forum members will appreciate that.Thanks for posting on the forum. Upvote 0 Downvote
H hacker 62 Honorable Jun 28, 2013 4 0 10,510 Jul 14, 2013 #4 thank you for your help Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jul 14, 2013 #5 Glad to help!!!!!!!!!!!!!! Upvote 0 Downvote
