Need help air cooling my gaming PC
UltimaSlayerVII
221
Hi, I am building a PC with the following specs:
EVGA 780i mobo
Quad Core Q9550 2.83GHz, plan to OC, but nothing extreme
Triple GTX 280 XXX OC edition in Tri-SLI
8GB DDR2-1066 RAM
Dual 300GB 10k rpm Velociraptors
1250w PSU
The case will me a CM 932 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160 because ive heard great things about it, such as being very roomy with great airflow.
But I'm definitely worried about heat. With 3 gtx 280s, dual velociraptors, and an OC'd quad core, I know this will generate insane heat. The case already comes with 3 230mm and 1 140mm fans, but I know its not enough.
So basically, what I'm wondering is how I should air cool this rig? How many and which fans I should buy, what CPU cooler/heatsink to get, where to place fans, etc. I really appreciate if anyone can help me on this
Thank you.
Also, water cooling really is not an option I'm afraid, because it will cost ridiculous amounts($1000+) for this setup.
I see you guys have nothing to do but look for threads I've created in search of help, and troll about my awesome GPUs that completely dominate yours.
QQ moar trolls. QQ more.
Yes sir master sir. Trolling is a nono. You of all people should know about trolling, Mr.Letmecreate3threadsonthesameexacttopicoverandoversoicanbragonmyimaginarysystemthatiwillneverbuildbecauseivebeentalkingaboutitfor2monthsnow
Three GTX 280s is too many in my opinion, what a waste of cash.
Just figured I would make this thread look like all the others you have started over this.
Ultima ur GPUS are a waste
a waste
a waste
a waste
a waste
Trolled enough for u?!?1
Get help somewhere else no one wants to help a jack***
Just for u Ultima its a perfect description of u
http://www.drunkensquirrel.net/v/2910
__________________________________________________________________
Anyways, like u thought was obvious if u want to air cool, put in FANS whoa that was hard. If I recall u called me out for saying something like that. Obviously it was too hard of a concept.
So u get some heatsinks, one for the cpu (Xigmatek S-1283, TRUE, Sunbeam Core Contact) and if u want 3 for the 280 that are tri sli certified (but i havent seen any yet, there are almost no heatsinks for the GTXs) and buy fans and AC MX-2 TIM. Then u install the fans and heatsinks and voila
How much do you know about watercooling to start with? If your new at this like we all were once, please read for a few days before asking basic questions. Many questions will be answered by yourself once you learn.
Here is a primer of places to go, cya in a few days. I have this as a document, just cut n paste every week or so for questions like your asking.
I'll steer you to some more technical links, please spend a few days (DAYS) reading posts, searching, learning.
Great place, not wayyy over the top with uber WC guys.
http://www.ocforums.com/index.php
Uber place, owned by one of the worls winning OC guys in the world. Not a place to post or ask questions by noobs, but an awesome place to learn.
http://www.xtremesystems.org/forums/
Another good place to learn
http://www.overclock.net/water-cooling/
The GURU of independant testing, worshipped by many.
http://www.martinsliquidlab.com/
Great places to buy WC stuff
http://www.dangerden.com/index.php [...] e&Itemid=1
http://www.petrastechshop.com/
http://www.jab-tech.com/
Hope it helps, see ya in a few days, get edumacated!
And In this case, please don't hijack another thread, especially this one, it's not going to be pretty.
:lol: :lol: :lol:
Dude, you asked the same question in 3 diffrent threads, got the same answer in all of them and come to ask it again!
No matter how many times you ask, the answer will be the same.
LOL
I betcha you are right on that one.
Just had to double check, the 4870x2 only has one CrossFire connection.
How much FAIL can you have in a single thread :pt1cable:
Ditch your stubborness and go reread the threads. Multiple answers were mentioned in those threads and it doesn't justify to keep trolling the forums asking the same damn question. :non:
I have used them before, good selection of all kinds of modding gear, but watch out for the markup. They are a little pricey.
http://www.heatsinkfactory.com/
These guys are decent for cooling supplies too.
LMAO you just made a TLDR post without even **** realizing he was asking you a question about running 6 gpus. Christ, grow a **** brain. if I could run 6 4780s, why the hell would I get 3 gtx 280s
Wow :ouch:
That slipped right past me!
I never even knew ATI released a 4780 :pt1cable:
Maybe you should read the last IDFK, FOUR THREADS YOU STARTED!
If you want that level of cooling, GET WATTER!
